Browse Forums Outdoor Living 1 Sep 05, 2012 4:47 pm Hello All I just want to make a small backyard waterfall. In a nutshell I just want to confirm the overall steps 1. Remove Weeds from the Area where waterfall to be built 2. Put the chalking around the area where digging has to be done 3. Dig the Area , as this will serve as the placeholder for water . In my case the area will be like 2m(length)*1m(width)*0.3m(depth) 4. Put the pond liner in the digged area 5. On one side of the digged area, start building the structure with stone (cascading structure) 6. Put the submersible pump in digged area and and get one pipe from pump to top of cascade structure 7. Connect the Pump to Electricity 8. Fill in the Pond 9. Turn on Pump and enjoy the fall. Please clarify if these steps are correct and also if you feel like there is more to any step, then please add it. Thanks Sami Regards, Sami Re: Backyard Waterfall Question 2Sep 05, 2012 5:21 pm I would build the pipe into the cascade structure rather than run it to the top after. Far neater and it can't be damaged inside concrete The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Backyard Waterfall Question 3Sep 05, 2012 6:13 pm yes plan ahead for this. basically you got it. use your imagination, water features are easy "ish" to build and not overly expensive for the result that can be achieved. I have seen some truly spectacular high impact water features done for under 800.00 all DIY Re: Backyard Waterfall Question 4Jul 31, 2013 9:18 pm SOunds like you are on the right track. What is the pumping head height and how much water do you want to come out of your water fall? DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16716 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9014 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24875 |
