Browse Forums Outdoor Living 1 Aug 16, 2012 10:11 am Im in the process of renovating our existing decking and need advice on colour matching. The deck is several feet above ground and previously had white lattice panels around it. The hardwood floor is currently painted a grey/ bluish colour. The metal frame is currently powder coated brown. Our outdoor table and chairs is coffee colour wicker style. Ive ripped down the lattice panels and am replacing with horizontal aluminum slats. The wife is concerned about too many colours being in the same place. So the question now is what colour to get the panels made? Colour for the deck to be painted? Colour for the metal frame to be painted? It would be good if we could see some examples of similar decking but i cant seem to find any. Any pointers? Thanks Re: Advice - Colour coordination 2Aug 18, 2012 3:24 pm Blue with brown, and white to set it off look good together. So do you just want to upgrade these existing colours for a better blend? Or are you going for something completely different? Also could you post a pic of the area- that would help a lot. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17768 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13842 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6903 |
