Browse Forums Outdoor Living 1 Jul 04, 2012 8:23 am Hi guys, I'm planning to do my own decking in the front patio and at the alfresco area. To start off, I will be doing the patio which is just a few sq m. So far, after asking bunnings i have the following things I need to do my decking: 1) Drill ($200) 2) Drop saw - $70 3) Treated Pine 4) Decking Screws 5) Merbau Decking It seems simple to me, I first need to create the structure around the area and with a spacing of .5 metres. Then I need to do the merbau decking around the structure first, then proceed with the decking. What the bunnings dude told me is I need to drill a hole first on the merbau before actually screwing it since it will be hard for me to drill the screw directly without drilling a hole. My question is, since I'm doing this on top of concrete, what do I need to do to put the structure in place? Do I just nail the structure to the concrete? Let me know if I'm missing anything as this is my first DIY project.... Re: doing my own decking? what do i need 2Jul 04, 2012 8:54 am there are plenty of threads on this already, u might just need to do a search. however i found this one to be most helpful on the * http://www.*.com/f196/bluem ... post869266 Re: doing my own decking? what do i need 4Jul 07, 2012 6:20 pm Have a look here also for more info, heaps on decks http://www.*.com/f196/ Re: doing my own decking? what do i need 5Jul 20, 2012 1:07 pm We are doing our own. After a LOT of research and gathered information we actually went to Softwoods who designed/engineering a plan and sold us a 'kit' so we just have to put it together basially. We have some areas attached to concrete which is done with brackets.. I suggest having a chat to them.. (unless you have actually purchased everything already) Building in Adelaide, SA Slab poured 08/09/2011 Handover 18/01/2012! WORLD CONCEPT HOMES Our build thread: viewtopic.php?f=31&t=44725 Re: doing my own decking? what do i need 6Jul 20, 2012 4:28 pm i haven't purchased anything yet... I checked their website and doesn't tell you how thei decking kits look like... did you end up spending less as compared to other options? I'm looking into no nails as of the moment using biscuit as per above links... Ashkate We are doing our own. After a LOT of research and gathered information we actually went to Softwoods who designed/engineering a plan and sold us a 'kit' so we just have to put it together basially. We have some areas attached to concrete which is done with brackets.. I suggest having a chat to them.. (unless you have actually purchased everything already) Re: doing my own decking? what do i need 8Jul 21, 2012 11:54 pm mine is around 5x5m, so i think i don't need one.. thanks atagnat ...maybe a building consent if the Alfresco decking is greater than 10m² Re: doing my own decking? what do i need 10Jul 22, 2012 7:07 pm They can do all different kinds of kits. We worked out maybe $2k at Bunnings plus this way we know we have just what we need, not doing a million trips to the shop for forgotten things etc.. Worth a chat to them! Building in Adelaide, SA Slab poured 08/09/2011 Handover 18/01/2012! WORLD CONCEPT HOMES Our build thread: viewtopic.php?f=31&t=44725 Re: doing my own decking? what do i need 11Jul 22, 2012 7:09 pm We were also told we didn't need council approval unless it was more than 500m off the ground, not by the size.. Building in Adelaide, SA Slab poured 08/09/2011 Handover 18/01/2012! WORLD CONCEPT HOMES Our build thread: viewtopic.php?f=31&t=44725 Re: doing my own decking? what do i need 12Jul 23, 2012 8:28 am hehe.. sorry mate.. will ask the council... atagnat 5m x 5m is 25m².....which is larger than 10m² You're better to check with your local Council if you need consent as it'll be a major hassle later. Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10972 The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give… 0 5172 Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 5054 |
