Browse Forums Outdoor Living 1 Jun 23, 2012 7:55 pm Could someone tell me if I can extend my decking over a storm water drain that is in my courtyard if I have an access hatch for inspections and maintenance? Where my storm water drain is affects the use of my courtyard so I thought if I could deck extend the deck over this drain would give me more usable area. Re: Decking over storm water 2Jun 23, 2012 8:08 pm Is it an easement? or your own drain Landscape Design & Construction http://cherub.squarespace.com/ Re: Decking over storm water 3Jun 23, 2012 9:06 pm stratastruggler Could someone tell me if I can extend my decking over a storm water drain that is in my courtyard if I have an access hatch for inspections and maintenance? Where my storm water drain is affects the use of my courtyard so I thought if I could deck extend the deck over this drain would give me more usable area. You can, as long as you can inspect it.. Re: Decking over storm water 4Jun 24, 2012 9:16 am Its a 500x500x500mm concrete storm water in my courtyard (am in a townhouse). At the moment the courtyard has one third decking off back door, then thrid paving, then lawn. With the position of the storm water drain next to the decking, and the angle of the pavers to allow water runoff it has created a bit of a "step" from the deck where the drain is. I thought that a deck right across would make for a more usable, even space. Re: Decking over storm water 5Jun 24, 2012 9:22 am If it's your own private drain and the access is big enough for a plumber to get in and work you should be fine! If it's an easement you will need permission from the holder of the easement. Either way a quick call to council maybe helpful, some councils want building permits, some want x free space under the deck, it all depends on your local council 2 Re: Decking over storm water 6Jun 24, 2012 10:25 am Have just managed to dig out the original drainage plans for my townhouse. Would it mention easement of these if it were? If so cannot see it mentioned on the loans. There is no access to this drain except to go through my place. There is a storm water drain of this type in every courtyard. From the plans it would seem that all these drains take the roof water run off from each townhouse and are connected to each other finally leading too a large storm water pit located in the common property area of the complex. Re: Decking over storm water 7Jun 24, 2012 10:45 am From what you have said it sounds like there will be an easement although it could be in favour of either the body corporate or the council. The title plans will show whether its an easement or not. See this link to find out how: http://www.anewhouse.com.au/?p=393. You will need to keep the foundations of the deck below the zone of influence of the pipe. See this link: http://www.anewhouse.com.au/?p=423 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7787 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6823 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 9508 |
