Browse Forums Outdoor Living 1 Jun 16, 2012 3:24 pm it started at to be 5m by 8m and now its about 5x9
plans are to have 9peice dinning and bbq with tv above the bbq closes to the laundry door then spa under the bathroom (half windows) and then outdoor loungne settings in front of that started on my deck Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 1st dam hole we drilled Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ all the wood loaded up Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ after 79bags of mix , that is all concrete but prob should of a just got a concrete truck and pump lol would of been cheaper and easyiser Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ up to 2 weekends work so far and hoping to get the joists and noggins in tomorrow then maybe starting laying the flooring on monday Re: the building of my deck :) 4Jun 19, 2012 10:01 pm Nice work,looks great. Cant wait to see it finished Re: the building of my deck :) 5Jun 20, 2012 10:12 am blacklab Nice work,looks great. Cant wait to see it finished Me too ... looking great - well done For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: the building of my deck :) 6Jun 20, 2012 10:36 am Quick question, what timber are you using for your joists? Landscape Design & Construction http://cherub.squarespace.com/ Re: the building of my deck :) 9Jun 21, 2012 6:04 am I thought so, I know you wont want to hear this but 90 x 90mm are not designed for the purpose you have used them for (posts) thus they are not listed in span tables. 2 45 x 90mm minimum, nailed together would have been a better option. Also 450mm is the max span for 19mm decking and 400mm recommended. Would suggest you add some more support mid span to reduce chance of failure. Landscape Design & Construction http://cherub.squarespace.com/ Re: the building of my deck :) 11Jun 23, 2012 2:43 pm Hi ply-boi - did you get building approval for this work? It looks like quite a big deck! If you don't have approval (normally required for any decking over 10m²), you may have trouble when you come to sell... Re: the building of my deck :) 12Jun 23, 2012 7:36 pm atagnat Hi ply-boi - did you get building approval for this work? It looks like quite a big deck! If you don't have approval (normally required for any decking over 10m²), you may have trouble when you come to sell... no approval, dont plan to sell any time soon but if we do i'll sort it out then Re: the building of my deck :) 14Jun 24, 2012 9:59 pm Hi mate, that looks fantastic! Can I ask roughly how much the materials cost you, and whether you had to hire any specific tools? I'm keen to do the same to my backyard soon, and haven't done a deck before. Thanks! Re: the building of my deck :) 15Jun 25, 2012 10:39 am Currently at just over the 5k mark The dingo is owned by missuss cousin so that was a few cases of beer abd We own the cement mixer And ive owned all the tools we're used so far being a sparky by trade The only thing ive bought is a cheap $200 compound mitre saw Re: the building of my deck :) 16Jun 25, 2012 11:58 am cherub I thought so, I know you wont want to hear this but 90 x 90mm are not designed for the purpose you have used them for (posts) thus they are not listed in span tables. 2 45 x 90mm minimum, nailed together would have been a better option. Also 450mm is the max span for 19mm decking and 400mm recommended. Would suggest you add some more support mid span to reduce chance of failure. Agree with the 2 x 45mm.. 400 max span? I had 500's and its fine. Also.. just on the council approval, some councils dont need one (mine for example) its good to check. Re: the building of my deck :) 18Jun 25, 2012 3:32 pm ply-boi Currently at just over the 5k mark The dingo is owned by missuss cousin so that was a few cases of beer abd We own the cement mixer And ive owned all the tools we're used so far being a sparky by trade The only thing ive bought is a cheap $200 compound mitre saw Thanks! That gives me a good idea of costs (most likely cost me more than 5k, haha), cheers! Re: the building of my deck :) 19Jun 25, 2012 4:18 pm ply-boi Well with using the 90x90s ive got a spans of joists at 800. With noggings and im using 140x25 flooring boards Are you spanning the decking 800mm? Landscape Design & Construction http://cherub.squarespace.com/ I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20231 DIY, Home Maintenance & Repair Thanks. I was thinking of using either Extreme Joist or LOWDECK timbers for joists. Any idea what sets them apart and which… 2 12886 I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3233 |
