Browse Forums Outdoor Living 1 May 02, 2012 7:46 pm We have a small backyard and are looking at clotheslines for our house to install when it is finished. The fence is 3.69 metres from the house. Block is 14 metres wide. Would really love a rotary clothesline, but not sure if one will fit. Thinking a hills 6 clothesline. Does anybody have some ideas as to what would fit. The other option we are considering is a pull out clothesline as we dont have enough wall space for a wall mounted. We could purchase posts I guess and put it in the middle of the yard. Options for clothesline - small backyard 2May 03, 2012 2:38 pm I would go with the hills 6, even if you had the room for a rotary clothes line you need to make sure you have enough space to hang sheets without them hitting the fence or house. Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16716 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9013 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24872 |
