Browse Forums Outdoor Living 1 Apr 13, 2012 12:08 pm Does anyone know where to buy skinny rainwater tanks in Adelaide at a reaasonable price? It seems the skinnnier they are the more expensive to the point it's not worth putting them in .... we're looking for something less than 400mm wide Cheers Annette For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Skinny rainwater tank 2Apr 24, 2012 11:24 am Hi McLaren, Wow 400m seems really skinny. I reckon you'll probably have to go made to measure with those sort of dimensions and that is really going to bump up your price. The smallest I found was 670m through Maxiplus for cubes that you can stack when we were looking for our previous house. Good luck My thread: viewtopic.php?f=31&t=55859 First time build = excellent. Second time build = frustrating. 23/4/12 Block Cut Skinny rainwater tank 3Apr 24, 2012 11:26 pm I think stratco had tanks that were about 400 wide, not sure on price though. Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 Re: Skinny rainwater tank 4May 12, 2012 3:50 pm Check out the tank in my thread! They are called thin tanks. Can't get any skinner than these! Re: Skinny rainwater tank 5Jun 26, 2012 10:37 pm got quoted on a 2000l thintank at 470mm wide it is bit less than $1300 then one the builers wanted to put in was worth 3500 and an eyesore Building the Montague 21 by Porter Davis at The Estuary, Leopold. Our Blog: http://porterdavismontague21.blogspot.com.au/ DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31465 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31298 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19727 |
