Browse Forums Outdoor Living 1 Feb 11, 2012 12:30 pm At our new house one side fence has the runners on our side, and a pool on the other. With a very inquisitive little boy, obviously I am eager to do something about this before we move in! While there's only about 10 meters abutting the pool enclosure that I absolutely HAVE to clad, if my boy gets over the fence into the neighbour's backyard, he could easily pull a chair up to the pool gate and get into the pool enclosure that way. So realistically I need to clad or somehow fix this so he can't get over the fence at any point. It's about 30 meters, all up. So I need ideas which are not going to cost a bomb. Of course, I want it to look nice, too!! Any ideas? Need ideas: Fence cladding 2Feb 11, 2012 4:29 pm You can put another rail on the fence and then screw tin on so it would look like a double sided fence. Brush screening could also be an option. Our council here will not let you have a pool if there are rails on the other side of the fence due to kids climbing over easily. Might be worth checking with your council if it's the same there. Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 Re: Need ideas: Fence cladding 3Feb 15, 2012 5:46 pm Yes we'd thought of corrugated tin as an option. I had a feeling that might be costly? Not sure on brush screening as so much I have seen sags after a while and looks crappy - and might also allow a foothold. There used to be a pool on our side of the fence, too, but we removed it before we built. I am pretty sure it would now be a requirement that the fence have double sided facings - at least on the section adjoining the pool enclosure. Maybe that's the solution? Put palings up on our side, too? I recently finished my house and after landscaping, have begun to plan a fence. To be honest its been a bit of an afterthought so I'm after some much needed advice. The… 0 2038 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12051 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11118 |
