Browse Forums Outdoor Living 1 Feb 03, 2012 2:42 pm Hi All, I have a 3000l external water tank which I collect water in for garden use only. (Grass & Veggie patch) It has a clear plastic pipe on the outside that indicates the water level & current capacity. I've noticed that it has started to fill with moss and grim of late. Can anyone suggest what I can use to help clean the inside of the tank and tube? Is there a simply method of adding something to the current supply? Thanks in advance. Re: Cleaning a Water Tank 2Mar 28, 2012 12:15 am The clear plastic pipe lets in light. It needs to be covered over with a split length of poly pipe or similar. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17540 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10834 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1672 |
