Browse Forums Outdoor Living 1 Oct 25, 2011 11:11 am Hello, According to our council regulations every block should have 60% of POS (private open space) of the total block's size with at least one open area of 6x6 m. Moreover, this 6x6m area should not be facing south or south-west which makes it quite restrictive. On my plans only one location on north side satisfies all criteria for POS (and POS is marked there) but I want to build a pergola attached to the building there. Can I partially cover a POS with pergola ? Re: Private open space requirements 2Oct 25, 2011 11:46 am It might help if you tell us where you are and which council you are dealing with. Are you sure you are talking POS or landscaped open space ? With our council ( Warringah ) we are supposed to have 40% landscaped or soft open space and 60sqm of POS for a three bed dwelling ( 36 sqm for a two bedder ) None of that is allowed to be under a roof of any kind although they will give you some leeway ( I think it is up to 25% ) with timber decks for open space. Stewie Re: Private open space requirements 3Oct 25, 2011 12:22 pm Yes, you right, I am in ACT and dealing with the act planning office. I called them and they said that I can put pergola on that POS area if it is located "to maintain a minimum three hours sunlight onto 50% of the ground of the area between the hours of 9:00am and 3:00pm on 21 June (winter solstice)". How can I calculate the sun's altitude on 21 June between 9am and 3pm ? Re: Private open space requirements 4Oct 25, 2011 2:20 pm This is the sun travelling across the sky - note this is the only diagram like this I could find and is for the Northern hemisphere. Just reverse the E & W and it is virtually identical for the Southern hemisphere except for the exact angles shown in the diagram below This is midday 21st June for the ACT and what I use to do my shadow drawings. Just do a rough guesstimate for the 9AM and 3PM and you should be reasonably close. Oops , that should read 76º Midday 21st December Summer Sun above . Stewie Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3582 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3665 I'm wondering if anyone knows what the requirements are of a builder to be eligible to hold Domestic Building Insurance for proposed works. https://www.dbi.vmia.vic.gov.au… 0 3334 |
