Browse Forums Outdoor Living 1 Jan 30, 2008 10:59 pm Hi guys,
We are soon to start building our house and are looking at getting a small concrete lap pool built down the side. Can anyone who has had one built recently let me know who they used and whethe they would recommend them? Thanks, Mathew Re: Anyone know a good concrete pool builder in Perth? 2Jan 31, 2008 1:00 pm make sure the pool is designed in with the house slab and built at the same time otherwise you will have to underpin the slab which costs around $1400 a sqmt
the last lap pool i quoted was in perth 8 mtrs long the underpinning came to $16000 i ended up building it 1.2 from house and 1.2 from boundary it was only 2 mtrs wide so quite skinny you dont need underpinning if the pool is from memory 1.2 odd mtrs from the house slab (pool companys can advise this) also if it is closer than 1 odd meter to the boundary then you will have to shore up or under pin your neighbours backyard and or house Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Anyone know a good concrete pool builder in Perth? 3Jan 31, 2008 11:57 pm My SIL has just had a concrete pool built by Five Star Pools. It looks fantastic and there were no problems during the construction of the pool. Easy enough to do, Builders get onsite trades while working on your build to put pool slabs and brick walls in during house builds. Tho, I've never seen one pass the… 10 12534 ![]() Hi folks, Looking for some guidance before I talk to the pool company. My concrete pool is yet to be rendered, so still at the raw concrete stage. There has been a lot… 0 4281 We assist homeowners and suppliers to industry investigate the credentials, reputation & credit rating of pool builders. We’ve helped hundreds… 0 2957 ![]() |
