Browse Forums Outdoor Living 1 Aug 28, 2011 8:16 am Hi there, Just got a property and had it inspected. The deck is (beautifully) built on untreated pine posts. The pest inspector said there is no evidence of termite/fungal problems. So, how do I go about having the posts treated so that it will resist termite/fungal attacks? Thanks heaps. Re: Decking problem: built with untreated pine, how to recti 2Sep 02, 2011 9:30 am One option (which is not easy) is to approach it like re stumping a house. Dig out the old post, make sure you have a secure footing or make a new one then put in a new treated post. you'll have to do it one by one though un less you can take the top section of deck off in one peice, then you could do all of them at once and not have to dig as much. Re: Decking problem: built with untreated pine, how to recti 3Sep 02, 2011 10:35 am Are the post Cyprus pine or hardwood?? They dont always need to be treated pine. Untreated Pine post are very hard to buy, I doubt they will be normal pine that would be used in a house frame. Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10976 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6592 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52859 |
