Pizza ovens- Brick or stainless steel
We are also looking at installing a pizza oven. Are the stainless steal ones powerd by fire or gas?
I know the 'taste' of a wood fired pizza can only be achieved through the brick ovens.
I agree - they are expensive!!
IMO the advantage of a true pizza oven is being woodfired. 2 minutes in the oven with a strong smoky flavour. MMMMMm piiiiiiiiiiiiiiza
http://www.woodfireovens.net/residentia ... red-ovens/
Harvey Norman has a good one, but since the outer is only 304-grade stainless steel, it might not stand up to our salt air environment. If that's not a concern to you, this one is pretty good. You can get it with or without the stand (stand has two slide outs on the side for prep and cutting areas)
http://www.harveynorman.com.au/furnitur ... stand.html
Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead…
16/11/2023
Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am…
18/04/2024
8
This is 100% true. You can not hang anything on steel frames. very frustrating
