How much should it be to add/include an external bbq gas outlet with the builder on average ?
Cheers
Rowan
Browse Forums Outdoor Living Re: External BBq outlet?? 2Jan 20, 2008 4:04 pm Hi Rowan,
Not sure of the price, there will be a few things to think about. Check on your plasns to see where the nearest gas line will be (Heating or hot water etc, then work out the distance. One thing to remember. BBQ gas and Natural gas burn at different temperatures and operate at different pressures. You will need a regulator to drop the pressure down. Also BBQ's may need different jets, and have also heard that hotplates and burners teld to last a lesser lifespan than Bottled gas. BTY, It is cheaper to get a small bottle refilled, but get a swap and go for 0kg bottles. weird...... Adrian B Re: External BBq outlet?? 6Jan 20, 2009 8:10 pm i had one installed a few years agon now about 5 years i think it was about $180 finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: External BBq outlet?? 7Jan 21, 2009 12:24 am Damn ...... ours was $350 ! 'We make a living by what we get, but we make a life by what we give.' - Winston Churchill Re: External BBq outlet?? 9Jan 22, 2009 12:11 pm Adrian B One thing to remember. BBQ gas and Natural gas burn at different temperatures and operate at different pressures. You will need a regulator to drop the pressure down. Also BBQ's may need different jets, and have also heard that hotplates and burners teld to last a lesser lifespan than Bottled Just out of curiosity, have any of you on here that have a natural gas fed BBQ had any of the above problems or any other issues? We are thinking of putting one in. AL. Re: External BBq outlet?? 10Jan 22, 2009 1:20 pm We have had one included in our new home (yet to be built). I know nothing about it and have not even thought about it. Do you need a 'special' bbq or is there a conversion kit or something? Thanks Re: External BBq outlet?? 11Jan 22, 2009 1:33 pm fairy blue We have had one included in our new home (yet to be built). I know nothing about it and have not even thought about it. Do you need a 'special' bbq or is there a conversion kit or something? Thanks http://www.gasmate.com.au/sub_categorie ... oducts/176 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ includes: - natural gas injectors (different orifice size to bottled gas) - bayonet socket - threaded adaptor - natural gas regulator - 8 mm hose fitting with bayonet fitting Looks like it may need to be installed by a gasfitter (?). mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: External BBq outlet?? 12Jan 22, 2009 1:38 pm Thanks for that quick reply, sorry about the hijack rowan. Before you rip it up, if you can in the grout lines, drill some holes and pour/inject techgrip by sika. I have used it to bond mdf to timber, but in the process it dripped… 1 4382 7 5212 |
