Browse Forums Outdoor Living 1 Jun 01, 2011 8:05 pm G'day, Does anyone on here have first hand experience with running gas pool heating? My friend has just built an above ground, sprayed concrete pool, 12.5m x 4.5m. We are in North Queensland, and he wants to heat the pool. He has been advised to install this heating system: http://www.davey.com.au/ApplicationandP ... aters.aspx In particular, the 280 model. (propane LPG) The info listed on the website states input as 261 Mj/hr, and output as 58kw. The burner pressure is 2.75 kPa and the injector diameter is 1.10mm. Can anyone help us decipher this information, so we can work out how much its going to cost him to run it? Any help would be greatly appreciated! Thanks, Mark 4 10824 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3668 |
