Browse Forums Outdoor Living 1 May 15, 2011 9:32 am We will be having two maybe three 20000 water tanks and have a large household of 8 people and heard a water pump with a holding water tank above it is best and want good pressure and to avoid temp changes etc. What tank pump would be best for our needs? Re: Water pumps which sort and cost 2May 15, 2011 10:10 am any manins pressure ones.. maybe go visiting pump shops.... or ask the mob who sold you your tanks Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Water pumps which sort and cost 3May 15, 2011 10:16 am We haven't got the tanks yet but plan to ask then too, just want to hear what people think is good. Doing homework. Re: Water pumps which sort and cost 4May 16, 2011 2:25 am When you get around to speaking to some about pumps they will want to know a few things like how far are you from the house to the tanks what is the head hight of water you will be pumping to are you pumping up a hill how many taps are you supplying all these things have a affect on the size of your pump reqirements. Cheers Heath Re: Water pumps which sort and cost 5May 16, 2011 4:10 pm Hi, Have you spoken to someone locally about your requirements? 40-60,000 litres seems a bit small for a household of 8, but it depends on your annual rainfall, roof collecting area and whether this is your primary water source or a supplementary source. I am building in an area which is reasonably wet (857mm mean annual rainfall), although it is all relative - this is dry compared to tropical North Queensland - and I have been advised to put in a 120,000 litre tank for a household of 6 with 600m2 of collecting area. Also, have you considered a single steel tank rather than multiple plastic tanks? The cost is comparable and they are better in a bushfire area - although if you need to fit the tanks into a narrow strip, multiple tanks would make sense. Paul This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28382 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8545 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20265 |
