Browse Forums Outdoor Living 1 May 07, 2011 8:49 pm hi can anyone tell me what the legal requirement is regarding distances around a pool, specifically the minimum distance from the wall of the house and also the minimum distance from the boundary fence I don't know if it different from state to state but I am looking at installing one in Perth WA thanks in advance Re: swimmning pool guidelines 2May 07, 2011 11:33 pm This is up to date and applies to all states... http://www.dip.qld.gov.au/resources/gui ... elines.pdf "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: swimmning pool guidelines 4May 09, 2011 5:32 pm there is no min for distance from pool edge to fence but it is recommended there be enough room to perform a rescue from the pool if / when required. Distance from house if above ground no min but fence must be 1200 from any platform or step etc if a flat wall then you can use this wall as a fence provide it meets all fence criteria. If inground then distance from house will need to meet engineering requirements ie 45 deg angle repose from bottom of house slab. Re: swimmning pool guidelines 5May 13, 2011 11:45 pm Would be interested to know if you find out dunkyboy as we are in Perth and considering a pool too. I was told for a fibreglass pool the distance it needs to be away from the fence/house is equal to the deepest depth of the pool ie.1.5 deep = 1.5m away from boundary. A concrete pool can be placed closer. Anyone know if that is right? Re: swimmning pool guidelines 6May 14, 2011 3:21 am Slightly off topic, but keep in mind that if you won't have a fence between the pool and the house, your windows opening onto the pool area will need to comply with pool safety laws. Your shire will advise you of what is required when you get approval for the pool, but there are restrictions as to how wide the windows can open (it is in case children get out of the window). If your window openings are too large, you will need to have the windows altered, or install a fence. Re: swimmning pool guidelines 7May 14, 2011 11:36 am We are building and live in Perth and have just had a pool installed and it had to be 1.5m from the back fence and because ours is right next to the alfresco we had to have footings put in. Building The Oceanic with Nautilus Upgrades by Dale Alcock Build thread: viewtopic.php?f=31&t=45433&p=687574#p687574 KEYS! 28.9.11 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 7984 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 12294 Murraya could be a great option for you. It creates a great tall screening hedge but doesn't drop fruit like lily pilly. The flowers smell divine. 2 7964 |
