Browse Forums Outdoor Living 1 Apr 27, 2011 3:02 pm Hi guys, Could somebody recommend me a shop/online store that has recessed solar lights for decking? I can't seem to find many nice ones and they all don't seem to be very reliable. I'm starting to think that solar decking lights aren't the way to go..might have to go down the path of LED lights instead... I don't know if this is possible or not, but are there lights that are connected to one another where they can share the solar energy generated? The reason I ask is because I've got an area of the decking which receives very little light during the day, but I still want to light this area up throughout the night without having to resort to using electricity. Thanks a lot guys! Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28804 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8810 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8551 |
