Browse Forums Outdoor Living 1 Apr 09, 2011 12:13 pm Hi all! We were considering getting someone to install a gas fireplace and build a wall surround around it, since we have a natural gas line to the side of the house where we intend to have it just outside a pergola. After doing the sums, this could be costly as I was looking at a rendered or tiled finished surround. And then I came across this,,, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It's a Coonara Fire Pit that can be used with natural gas. I am considering this because it takes out all the extra costs thats need for a wall gas heater to look 'extra nice' and when not in use, you get a cover for it so it can double as a table. I like the look of the stainless steel, gives a modern edge. We would consider having this under the pergola roof that will be approx. 9 foot high and that has open sides. Does that sound okay for ventilation? The only worry is the beautiful glass can get a bit blackened on the inside after some use so I was wondering if anyone has this and if the glass is removable for cleaning or anything else I should be aware of? I really like this one. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ __________________________________________________________________________________________________________________ All new built homes look like display homes... until the furniture goes in. Re: Outdoor Fire Pit. Anyone have one of these? 2Apr 12, 2011 5:33 pm gas wont blacken the glass. You will need a fire grate all the way around it so kids and drunk ppl dont get burnt Havnt used this type so cant say if good or bad type in the brand and make in google and look up reviews of the product Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Outdoor Fire Pit. Anyone have one of these? 3Apr 14, 2011 5:35 pm Yeah, forgot about the kids & drunk people... Thanks for the advice Davinci __________________________________________________________________________________________________________________ All new built homes look like display homes... until the furniture goes in. Re: Outdoor Fire Pit. Anyone have one of these? 4Apr 15, 2011 6:46 pm Considered a smaller gelatine fire pit or wooden one? You can get some impressive ones and will be easier to move as not require a hard line. And eventually if you decide you want to replace it with a future trend, it will be much easier. Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10466 We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5250 Need some advice. Living in a townhouse with one common wall, recently we have discovered that the fire separation wall is incomplete and on further investigation, support… 0 3856 |
