Browse Forums Outdoor Living 1 Mar 02, 2011 8:59 pm Hi, I posted this in another topic a while ago but wasn't getting many bites. Thought I'd try a dedicated thread instead. We are getting a pool and putting a water feature (waterfall) right next to our adjoining fence. When I say 'right next to', I mean practically touching. The waterfall is 800mm in depth and is 1000mm tall. We are actually upgrading our adjoining fence to Colorbond, the standard size being 1800mm tall. This means there will be 800mm above the waterfall to the top of the fence. Is this an issue? Our neighbours don't have a pool, nor do they really have room for one. I know there has to be a zone of 900mm of climable objects but that is from the 'non-pool' side. This is really the only spot for the waterfall so I really hope this is not an issue. If this IS a problem, we can perhaps get a custom size Colorbond fence...does anyone know if Colorbond fence can be custom made to 2200mm? If anyone can shed any information on this it would be greatly appreciated. Thanks! Re: Adjoining fence with Pool (pool side) 2Mar 03, 2011 2:05 pm Can anyone answer this? I'm made a few phone calls today and everyone seems to give me different information. One person said that the distance between the top of the water feature and the top of the fence must be 900mm or greater. The next person said that the distance between the top of the water feature and the top of the fence must be 1200mm or greater. The third person said the water feature could be there regardless of heights because it's on the pool side. Then he changed his mind and said, hang on it's the other way around, can't be there at all regardless of height. Bejeezus!!! It seems no one has a clue. Anyone know what the correct answer DEFINITELY is???? Thanks!! PS. I've found out that Colorbond also comes in 2100mm but you need a permit. Would rather use 1800mm but I guess the 2100mm is there as a backup depending on what the bl00dy rules are Re: Adjoining fence with Pool (pool side) 3Mar 03, 2011 2:31 pm If you ring your local council they will be able to tell you. I know that with our pool inspections, the council have only been concerned about climbable objects near the pool fencing where kids can put their feet through the fencing and use an object to climb over but with a solid colorbond fence this isnt an issue, if they can get over the colorbond fence from the other side they are already on the pool side so I dont see how this would be a problem, but check with your council. Re: Adjoining fence with Pool (pool side) 4Mar 03, 2011 2:39 pm Thanks Piscean. I already rang my local council and they said the distance between the water feature in the pool area (touching the adjoining fence) and the top of the colorbond fence would need to be 900mm or more. But he didn't sound too confident. And as I said, I got two different answers from two other people. Anyone else know for sure? Re: Adjoining fence with Pool (pool side) 5Mar 03, 2011 10:40 pm "I already rang my local council and they said the distance between the water feature in the pool area (touching the adjoining fence) and the top of the colorbond fence would need to be 900mm or more." I would double check this and ask to speak to the planning dept. It doesn't make sense where there is a solid fence because from the outside it would (presumably) already be 900mm tall from outside the pool area to stop a child getting into the area and that is what pool regs are concerned with. I think the person you spoke to may have been confused with pool fencing and boundary fencing. Like I said, my council who do an inspection every four years have never been concerned with the solid boundary fencing, but if something is too close to the sides which have pool fencing they'll move it or tell us to move it and keep it away from those sides. Do you have a contract with a pool company that includes the water feature? The pool company will know because they are usually the ones that submit the plans. The planning dept usually know their stuff because they are the ones who will approve the application but if you get some bod at the council who just reads the regs and doesnt know how to interpret them or what their intention is, they'll just fob you off with some half baked answer. Re: Adjoining fence with Pool (pool side) 6Mar 04, 2011 6:48 am Yes I have a contract with a pool company that includes a water feature. He wasn't 100% sure either but thought the fence would have to be 1200mm taller than the water feature. So dividing fence would need to be 2.2m. If the council person is right and the fence should be 900mm taller, than the fence would have to be 1.9m. I personally don't get it. As long as there is no climable objects in a 900mm radius on their side of the fence I wouldn't think it matters what I have on mine (especially since the fence is solid). Thanks for the info though mate. I guess ill keep trying to find the correct answer. Re: Adjoining fence with Pool (pool side) 7Mar 04, 2011 12:07 pm Well I've ignore the so called experts and spent some time this morning reading MP 3.4 Swimming Pool Barriers. And it looks like there's no problem with me having a water feature in the pool area smack bang against the adjoining fence. Even with a 1200mm fence it would be fine, as I'm using colorbond and there will be no climable fence rails on the outside of the fence (side facing away from pool area) (and also nothing in the non-climable zone). It seems the only time this would be an issue is when the fence uprights are more than 10mm apart. In this case you need to have a clear distance of 300mm on the pool side. With colorbond, this also won't be an issue. The MP 3.4 document can be found here: http://www.dip.qld.gov.au/resources/law ... rriers.pdf This is a direct copy and paste from the document: 6. The non-climbable zone must be located, for a fence, including a boundary fence: (a) less than 1800mm in height - on the outside of the fence (i.e. the side facing away from the pool area); and (b) 1800mm or more in height - on either the outside or the inside of the fence. 11. For barriers 1800mm or more in height, any non-climbable zone on the inside of the barrier (i.e. the side facing into the pool area) may be intersected by a swimming pool barrier, provided the width of the top rail or surface of the intersecting barrier is not more than 50mm wide at any point within the non-climbable zone (see figures 14 (a) & (b)). 13. The dimension of 900mm applies instead of 1000mm and is measured from the top surface of the highest lower horizontal member to the top surface of the lowest upper horizontal member or surface. So yay for me!!!!! Thought I would post this incase anyone else needed to know this info. Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 21156 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12531 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 7064 |
