Browse Forums Outdoor Living 1 Jan 11, 2011 9:20 am Re: my first deck...bearer problems! 2Jan 11, 2011 9:32 am Do you have posts in the ground in the middle anywhere to support the structure? Also are you meant to have double horizontal slates of various sizes laid near the boarders? Re: my first deck...bearer problems! 3Jan 11, 2011 9:34 am Dollar Do you have posts in the ground in the middle anywhere to support the structure? Also are you meant to have double horizontal slates of various sizes laid near the boarders? thanks Dollar..Yes, we do have the post in the middle..however, the bear is horizontally attached to the post and there's only one.... Re: my first deck...bearer problems! 4Jan 11, 2011 9:39 am Your image is so tiny... the joists appear ok, but you need double the joists for the bearers... Re: my first deck...bearer problems! 6Jan 11, 2011 9:41 am I have no idea about this stuff. Good on you for giving it a go. We are going to do decking for our uncovered area, well DP is going to give it a go. Do you think there is anything wrong with it? I would think you'd need more posts in the ground. How hard has it been so far to do? Getting it level, doing the post stuff? Re: my first deck...bearer problems! 8Jan 11, 2011 9:50 am Here's your pic... http://i896.photobucket.com/albums/ac165/aaron4erin/deck.jpg Here's ours, hope this helps... http://i896.photobucket.com/albums/ac165/aaron4erin/1deck001.jpg http://i896.photobucket.com/albums/ac165/aaron4erin/1deck004.jpg http://i896.photobucket.com/albums/ac165/aaron4erin/1deck006.jpg http://i896.photobucket.com/albums/ac165/aaron4erin/1deck008.jpg We used 200x200mm stumps, spaced 1400mm apart. Bearers were 2x 90x45mm = 90x90mm, spaced 1200mm apart. Joists were 90x45mm, spaced 450mm apart. Decking boards 140mm, spaced 5mm apart. Re: my first deck...bearer problems! 10Jan 11, 2011 9:54 am kb46 Your bearers look to be on their side? Re: my first deck...bearer problems! 11Jan 11, 2011 9:55 am just Erin Here's your pic... http://i896.photobucket.com/albums/ac165/aaron4erin/deck.jpg We used 200x200mm stumps, spaced 1400mm apart. Bearers were 2x 90x45mm = 90x90mm, spaced 1200mm apart. Joists were 90x45mm, spaced 450mm apart. Decking boards 140mm, spaced 5mm apart. Thank you Erin !!! So we definitely need double bearers...is it correct to attach the bearer horizontally to the stump ? Or it can only well carry the weight if it's vertical ? Re: my first deck...bearer problems! 12Jan 11, 2011 9:57 am amyife Thank you Erin !!! So we definitely need double bearers...is it correct to attach the bearer horizontally to the stump ? Or it can only well carry the weight if it's vertical ? Re: my first deck...bearer problems! 13Jan 11, 2011 9:58 am just Erin kb46 Your bearers look to be on their side? ok, this explains my question..it needs to be vertically attached to the stump... not sure how to re do it .... Re: my first deck...bearer problems! 14Jan 11, 2011 10:01 am Looks like you need to remove all the joists, and start again with the bearers. You will need to put two boards upright next to each other for the bearers. Upright, not flat on the stumps like they are now. Sorry I'm bad at giving instructions! Re: my first deck...bearer problems! 15Jan 11, 2011 1:04 pm How big are your post? I dont think they are big enough to hold all that weight. Idiots are fun, that's why there is one in every village! - Dr. House - Re: my first deck...bearer problems! 16Jan 11, 2011 1:18 pm Your post/stumps should be coincident with where the bearer and joist connect. Structurally having the post midway between bearers is less than ideal, and yes your bearers need to be flipped. Can I politely suggest you grab this book from Bunnings/Mitre 10/Dahlsens http://www.seekbooks.com.au/book/Austra ... 217106.htm It has basic design layouts, load tables and construction techniques for less than $30. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: my first deck...bearer problems! 17Jan 11, 2011 1:54 pm To everyone above, Thanks for all your kind suggestions and help! If I'm gonna tell you it's actually something done by "professional" people .. believe it ? I suppose it's done by "professionals" which I don't need to worry about at all... I saw their online profile received good feedback from others as well.... They started the frame yesterday, and when I back to home, I found this issue, which I cannot say 100% wrong, but definitely not in a best or normal way to do it ..... I just talked to their supervisor and pointed out the problems, but he told me they've done many jobs like this... however, finally, he agreed to fix it... What I'm told now is they will be cutting the post about 40 mm and flip the bearer upright .... Re: my first deck...bearer problems! 18Jan 11, 2011 2:03 pm Just make sure the bearers are double up, they need to not only flip it, but add another length for maximum strength. Unbelievable that they think they can get away with charging clients to do a job like this that will encounter problems in no time! Be tough, dont accept anything less than would should be standard Re: my first deck...bearer problems! 19Jan 11, 2011 2:54 pm 90x45mm treated pine laminated to 90x90 max bearer spacing cntr to cntr is 1.2 mtr 90x45mm treated pine joist max cntr to cntr with a 140mm board is 600mm but it bounces so go 450mm cntrs the joists in pic are joined wrong they should be butt joint over bearer cntr with a 45' angle and nail plated both sides there should also be ant caps on top of stumps and the stumps would preferable be concrete with the location pin through cntr of bearer in melb the deck in pic wouldnt pass an inspection for permit Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: my first deck...bearer problems! 20Jan 11, 2011 3:34 pm davinci 90x45mm treated pine laminated to 90x90 max bearer spacing cntr to cntr is 1.2 mtr 90x45mm treated pine joist max cntr to cntr with a 140mm board is 600mm but it bounces so go 450mm cntrs the joists in pic are joined wrong they should be butt joint over bearer cntr with a 45' angle and nail plated both sides there should also be ant caps on top of stumps and the stumps would preferable be concrete with the location pin through cntr of bearer in melb the deck in pic wouldnt pass an inspection for permit thanks for the advise! now, it's too late to fire them but I just accepted their fixing option, to put back the joist and then cut the post and then flip the bear , add another bear to give double support ..... looks like the best remedy ? ... Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9079 Hi Mrboh Just wondering if you have any BAL or flame zone issues on your block, as getting compliance with BAL requirements whilst doing bearers and joists is tough. Not… 1 8373 I am not a brick expert, but rendering would be 1 option, it would be costly to do the entire house though.... 2 6683 |
