Browse Forums Outdoor Living 1 Dec 21, 2010 6:53 am Hi, I'm building a deck with steel posts (deck height is about 1.5m). I have a question about how to align the steel posts to the correct height. Obviously I cannot cut them once they are in the concrete so I'm not sure how I align them so the bearers are all at the correct height. (the bearers are F17 150x50 - so very heavy) Any ideas please? Re: HELP - aligning steel posts for a deck 2Dec 21, 2010 8:17 am Use a water level. Basically some clear tubing with water in it, bend the tube and the water will end up at the same hieght at each end. Use a large diameter tube - less likely to kink. Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: HELP - aligning steel posts for a deck 4Dec 21, 2010 9:11 am I was thinking a string line - but I'm concerned the posts will sink on the concrete as it hardens. My other thought was to join the posts to the bearer on the ground ****** flat on the ground- dig the holes and then build a temporary support to hold them upright in the holes while the concrete sets. Unfortunately I think the whole structure will be too heavy so (without a couple of blocks and tackle) this won't be possible. Grant Re: HELP - aligning steel posts for a deck 6Dec 21, 2010 5:44 pm 1. concrete a single end post in position 2. bolt the bearer to the other end post, erect and bolt to the fixed pole, concrete2nd post in position. (If its too heavy with the bearer use a 100x 50) and replace with the bearer afterwards. 3. Hang any intermediate poles from the bearer and concrete in position The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: HELP - aligning steel posts for a deck 8Dec 24, 2010 5:00 pm Laser level all posts and clamp two pieces of timber across the bottom of each post so the timber sits flat on the ground while concrete dries. ensure you have min 100 mm of concrete between post base and bottom of hole. Here is a link to some steel channel posts i did for my deck. viewtopic.php?f=17&t=19439 Re: HELP - aligning steel posts for a deck 9Dec 24, 2010 5:20 pm personally i,d leave them slightly too long and cut them to height after concretes set.i used to site demountable buildings on steel posts and that was the easiest way i found and bang on every time Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14618 Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not… 8 9147 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7194 |
