Browse Forums Outdoor Living 1 Nov 29, 2010 9:06 am Ok, well we were planning on getting our deck built this upcoming weekend...but a builder friend of mine has strongly urged me to get tiles instead. He gave me a few reasons: 1. We wanted the deck to be 14cm above ground level, but he felt this would make the area too small (from a height perspective) 2. Fixing over concrete, Modwood must have 6mm gaps - all kinds of stuff will make the way under the deck including food (barbecues etc.) 3. Very difficult to check for termite trails and check termite barrier 4. Dogs may 'relieve' themselves under the deck - bad smells etc. 5. Potential breeding ground for spiders/snakes So...we are now going for tiles lol. Decking was going to cost us around $5000 for a 36 squared metre area...so should be able to save alot of $$ as well. What tiles do people recommend? Natural Stone (ie. Travertine, Granite etc)? Even though the decking was going to cost 5K we want to keep the tiles as cheap as possible. Cheers Re: Outdoor Tiles 2Nov 29, 2010 11:16 am Hey - we're tiling with large format limestone (800x400) from Amber - about $100/m2 to purchase then about $40-65/m2 to lay. It's only cheaper if you go for ceramic outdoor tiles - in my mind, they never look as nice as real stone, however the cost is prohibitive. After 4 years - we're in! Re: Outdoor Tiles 3Nov 29, 2010 11:28 am What is Travertine Polished Porcelain? I thought Travertine was Natural Stone? Anyone recommend these (see link below)? Top Tiles currently have a sale and nothing is over $25/square meter. http://www.toptiles.com.au/index.php?pa ... &Itemid=90 Re: Outdoor Tiles 4Nov 29, 2010 12:37 pm We were going to have a low deck but found some standards that said we needed a 300mm clearance for air circulation and pest inspections. Now going with slab and tiles. Found the bigger tiles are more expensive. Found tiles we liked nowhere near $25 for a 600x600mm tile. Re: Outdoor Tiles 5Nov 29, 2010 2:54 pm Travertine is natural stone - not porcelain. It might be a porcelain tile manufactured to give a travertine look. Besides - you won't want polished for an outdoor area - it would be extremely slippery. You could always give it a non-slip coating but then that would affect the look of the tile. You'll need to look for specific outdoor tiles - they'll have a bit more of a rough surface to provide grip when wet. After 4 years - we're in! Re: Outdoor Tiles 6Nov 29, 2010 2:54 pm Trade price in Melb: add app. 15-20% for retail Cheaper in WA as most shipping containers land / stop over there first then other states 500x500 granite $33-$40 sq mtr 500x500 splitface sandstone $33-$40 sq mtr 500x500 first rub bluestone $40-$50 sq mtr 610x610 travertine honed unfilled $85 sq mtr Conc slab per sq app. $70 Lab to install tiles $70-$120 sq dependant on how good the installer is + excavation, drainage if needed Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Outdoor Tiles 7Nov 30, 2010 7:01 pm We finally decided to go travertine tiles (from Sareen Stone) ... several reasons why: 1) Needed something around the pool and courtyard that would have reasonable traction but wouldn't conduct the heat (some of the other products convey the heat). 2) Consider the glare that comes off the tile - don't want to be squinting all the time! 3) We have a few trees around the place and I'm not the best at sweeping on a daily basis so needed something that could be sealed and would look alright if there were a few marks on it (a lot of the concrete tiles because they have no real variation in them show marks up more). 4) It is reasonably hard product and wasn't going to wear away (some of the other stones are less resistent to salt water attack even if you seal them etc) ... so we landed on travertine tiles ... Re: Outdoor Tiles 8Dec 09, 2010 3:32 pm In the end we have gone with a nice looking external ceramic tile (dark grey in colour). Has a slip rating of 12 and is 400mmx400mm. Getting it at a good price of only $25 per square metre. Don't really know much more about it than that. Are ceramic tiles ok to use around a pool? thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1698 Thanks for letting us know. The programmer will have a look at this later today. 2 6692 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29621 |
