Browse Forums Outdoor Living Re: bbq - stainless steel or enamel 2Nov 03, 2010 1:58 pm Stainless can tend to crack if it gets too hot and then cools down quickly. Enamel coating tends not to work too well on BBQ plates as they get banged up a bit more than in your kitchen(mine do anyway) Cast Iron will absorb all of the flavors (and odors) of the food you cook and it will transfer into the next thing you cook . Not good if you like to BBQ fish. I looked at some mild steel plates for my cooktop in our new kitchen, they were recommended by a specialist appliances center. I'd go either Mild Steel or Stainless if you plan on cooking fish. Cast Iron or Mild steel if no fish Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 6714 The yellowing mainly occurs to white or very light colours. 1 2922 This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18126 |
