Browse Forums Outdoor Living 1 Apr 10, 2006 10:35 am Hi all, I am new to this site and wanted to know what sort of lighting is suitable to be installed inside my garden shed? The use of 'skylight' is not so suitable because the shed is located under a tree where there isn't much sunlight. I found a couple of solar shed light through the Internet but most of it is available only in the UK market. I was wondering if there is any garden shed light that is sold within Australia? If none, any suggestions on how I may install a lighting within my shed (no mains power available)? Thank you !! Re: Garden Shed Light 2Apr 10, 2006 4:05 pm I've seen a battery operated light fitting, (like a small oyster light) which can be mounted just about anywhere. It comes with a click switch on the side. I'm sure Bunnings is a supplier, even your local lighting store. I don't recommend solar powered because the amount of light omitted is minimal:) Re: Garden Shed Light 4May 31, 2007 11:41 am HomeGal If none, any suggestions on how I may install a lighting within my shed (no mains power available)? Thank you !! Late I know, but can you tack a thick low voltage cable to a fence, or dig a shallow trench. Low voltage doesn't require a conduit - you could put a decent (and relatively cheap) light in the shed that way. I can explain further if you still need this light. Derek. Re: Garden Shed Light 5Oct 17, 2007 10:48 am It's all low voltage so extending the wires shouldn't be too hard at all.
by that i mean if the solar panel has to be further away than the wires provided are allowing you then extending them your self is really easy Re: Garden Shed Light 6Oct 17, 2007 10:55 am Hey homegal, look at the solar options available these days... I have seen some lights around, Bunnings should have them, that collect the suns rays in a solar panel which is connected to a light via a cable.
No ongoing costs either and you should be set. Re: Garden Shed Light 7Oct 17, 2007 1:13 pm ** Pheonix ** wrote
Quote: I have seen some lights around, Bunnings should have them, that collect the suns rays in a solar panel which is connected to a light via a cable. No ongoing costs either and you should be set. Wouldn't opening the window on a sunny day be easier Seriously There are some on going costs as the solar charged battery will eventualy need replaceing but it is certainly a low implmnetation costs option. For those odd times the sun is not shining and you want to be in the shed Steve Re: Garden Shed Light 8Oct 17, 2007 1:26 pm Yeh but i'm sure if you need to go out there after dark, the battery would be able to hold the charge for a decent period of time like all solar appliances.
Homegal, try lloking for something like these: http://dstore.com.au/homewares/Solar-Powered-Garage-LED-light/995462.html OR maybe: http://solarled.com.au/ViewItem.php?ItemID=40 or: http://www.todae.com.au/comersus2/store/comersus_viewItem.asp?idProduct=615 Bunnings should have something that you can see too. Weigh up your options and go with what will work best for your requirements. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4899 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5416 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3427 |
