Browse Forums Outdoor Living Re: How to guide for decking on concrete. 5Oct 12, 2010 8:17 pm Hi Dylan...pretty much from A to Z of paving - materials needed/prep work before laying on concrete...different steps involved and regular maintenance required.... 26/2 - Sales 23/3 - Colours 31/3 - Tender 14/4 - Contract 7/5 - Taps 12/6 - Site start 15/6 - Slab 27/6 - Frame 1/8 - Lockup/Fixing 29/9 - PCI 25/10 - Handover Re: How to guide for decking on concrete. 6Oct 12, 2010 8:28 pm I have a couple of photos but dont know how to post them on here. I dyna bolted some 45x90mm treated pine to the concrete 450mm apart then screwed the decking boards to this. Being carefull not to put dyna bolts where i would put the decking screws. As for maintenance this part has none, Just the stain or sealer is the only maintenance for this setup. Re: How to guide for decking on concrete. 7Oct 12, 2010 9:12 pm heater07 if you find one let me know........... thanks! There is one....I can't remember what it's called..it comes as a separate pamphlet with almost every edition of the Master Builders magazine. I'll post next time it arrives. Re: How to guide for decking on concrete. 8Oct 12, 2010 9:42 pm Dylan I have a couple of photos but dont know how to post them on here. I dyna bolted some 45x90mm treated pine to the concrete 450mm apart then screwed the decking boards to this. Being carefull not to put dyna bolts where i would put the decking screws. As for maintenance this part has none, Just the stain or sealer is the only maintenance for this setup. Use photobucket or something similar to upload the photos and put the image link in here... 26/2 - Sales 23/3 - Colours 31/3 - Tender 14/4 - Contract 7/5 - Taps 12/6 - Site start 15/6 - Slab 27/6 - Frame 1/8 - Lockup/Fixing 29/9 - PCI 25/10 - Handover Re: How to guide for decking on concrete. 9Oct 12, 2010 9:48 pm Youtube could be worthy for a look Where you are coming from is where you are going to... Re: How to guide for decking on concrete. 10Oct 12, 2010 10:38 pm I googled some really good threads a few months ago showing step by step the whole process with heaps of photos and great descriptions but I'll be damned if I can find them again. Thought I had book marked them. Re: How to guide for decking on concrete. 12Oct 14, 2010 8:30 pm Check out my thread for some pics...but this is what I did... Pour slab with a slight fall..enuf so water runs off but not so much the BBQ runs away Bolt your choice of joists (depending on the height you need ) to the concrete...we put ours min 450mm apart Lay boards...we chose to use kleva clips and modwood so we didn't see screws/nails Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10971 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15795 |
