Browse Forums Outdoor Living 1 Jul 15, 2010 10:49 pm Hi all, We're about to move into our new home. At the moment our alfresco area is a sandpit - we asked our builder to not pave the area as the plan is to put some timber decking in. I was reading through some other threads on H1 the other day and saw some people talking about the minimum height for a timber deck being 30cm, to ensure there are no problems with dampness in the joists and bearers. With this in mind, will we need to rethink our plans? The photos below show where we want to put the decking in, with the dark shaded area in the first photo showing the approximate dimensions of the planned deck. Any advice or recommendations would be fantastic! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ New beginnings. Re: Alfresco decking 3Jul 17, 2010 12:49 pm Check with your council for regulations - they should be able to give you some guidance on what your options are. Re: Alfresco decking 4Jul 17, 2010 4:43 pm wouldn't be a drama, you need to remove some soil and address the drainage issues. I'd look at steel bearers/joists for a situation like your, seen it done plenty of times Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 11706 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4246 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15957 |
