Browse Forums Outdoor Living 1 Jul 11, 2010 4:36 pm Hi, We recently finished a rennovation and would like to reclad our small backyard (currently built as a pailing fence), with timber shingles. Has anyone had experience with installing shingles over an existing pailing fence, or will we need to remove the existing fence, build it up with a flat surface (like outdoor ply) and then clad? Also does anyone know if there is a weight problem doing it this way? Thanks for your help. AJ Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12189 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11244 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5763 |
