Browse Forums Outdoor Living 1 Apr 04, 2010 10:25 am So I am looking at building a deck out the back of the house. I am considering using steel for the frame for a couple of reasons - less pest concerns and I am probably better at welding than using timber. I will probably just use RHS for the posts and frames.
Now what I want to know is what size RHS should I use? 50x50x2mm? Would that be strong enough? Also how far apart do I need posts, joists etc? Feel free to add anything else I need to know. Thanks in advance. Re: Steel framed deck - Suggestions? 4Apr 18, 2010 12:13 pm Stratco makes a turnkey solution; we have one for 2-3 years now, and it works well. Everything fits into saddles etc, so no welding, minimal screwing (we had someone install it). We'll have the same again, on a larger scale, when we replace another deck; only issue we have is to either nail or screw the timber to the joists... Re: Steel framed deck - Suggestions? 7Apr 20, 2010 5:12 pm Hi i have done exactly what you want at home already do a search under outdoor decking or i will add the link shortly i used 75x40c5 mm duragal channels for posts and bearers and 75x50 2mm rhs for the joists photos on homeone show this quite well. Decking and pergola projects is the headline just search let me know how you go viewtopic.php?f=17&t=19439 this should be it where are you located maybe able to help with supply of steel. Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5710 So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23021 |
