Browse Forums Outdoor Living 1 Feb 16, 2010 7:21 am We are renovating our house near the beach and want to include an outdoor shower which will be plumbed into mains water. Have looked for shower head etc but am being told that most will rust. Where do I find a shower head that will not rust?? If I find shower head plumber should be able to provide rest. Happy for it to look rustic. Have seen copper in a magazine. Should we go copper or marine grade stainless??? What do we get and where?? Re: Outdoor shower 5Oct 13, 2010 1:58 pm Hi Can u pls let me know if the outddor shower also needs to have a hot water supply? Re: Outdoor shower 6Oct 20, 2010 3:23 pm Hot water for an outdoor shower would be a preference of the owner. Beach house of a friend of mine is cold only. Would be nice sometimes to have hot water, but it really is only to wash the sand off Re: Outdoor shower 7Oct 25, 2010 3:32 pm HI, we are in a marine environment too, and have an outside shower right by the canal water edge. We have just used the same fittings that were installed for the inside showers (our builders standard range). I was researching about marine grade stainless steel outdoor showers and decided to wait and see how these fair. I am pleased to say they have no pitting what so ever. They have been there for at least 18 months. However, our al fresco lighting does show pitting and they are about 2 metres further back than the shower. If cost is a factor, try the same ones as inside the house ... I will post a photo later of ours. Also, a tip ... we were told to spray the outside steel with a coating of oil .. we got the heavy duty spray can oil for marine environment from BCF in a can ($12.95) or you can use the spray on fish oil stuff too (the lighting people told us this tip) Also, we have the hot water piped to it aswell as the cold. http://i662.photobucket.com/albums/uu350/davdenwa/25October2010022.jpg Re: Outdoor shower 8Oct 27, 2010 10:30 am This is a girlie question i'm sure, Is/can the shower be run/connected off an outdoor taps piping. Or does the piping have to be layed/planned for during the build! Told ya it was a girlie question cheers Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Outdoor shower 9Oct 27, 2010 10:54 am As we wanted hot water our plumbing was done during the build. I think if you want cold water and there is a tap nearby, with a bit of work ... depending on it's location and what is around it, you could connect a cold water shower from that. HOt water may be trickier and would probably be cheaper, easier if done during the build. Re: Outdoor shower 10Nov 08, 2010 2:36 pm Hi Goodyear, We just completed our outdoor shower near the pool. Went for the hot and cold option as teenagers and grandparents get picky! The rose is 30cm diameter which might be a little over the top but it's great to stand under Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Jonathan Building the Caprice33 by Provincial Homes. Now it's time for the landscaping http://jacksonsbuild.blogspot.com Re: Outdoor shower 11Nov 08, 2010 2:44 pm WOW That is GORGEOUS/STUNNING,what a feature Is the wall flag stone My man has no idea about the outdoor shower idea yet ,another suprise for him I have managed to get in another tap to the back of the house,just have to work out the right spot for future pool,the hot water & outdoor kitchen,Sorta sneak it in Picky kiddies here too Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Outdoor shower 12Nov 08, 2010 2:56 pm kerry-ann WOW That is GORGEOUS/STUNNING,what a feature Is the wall flag stone The wall is solid sandstone. Each block is 2m long by 500mm x 500mm. Each weights 1.5ton. Not cheap, but ain't going anywhere Building the Caprice33 by Provincial Homes. Now it's time for the landscaping http://jacksonsbuild.blogspot.com Re: Outdoor shower 13Oct 19, 2011 3:28 pm I'm so glad I found this! We are putting in an outdoor shower too, definitely with hot water as we sometimes get home from the beach late in the afternoon and need a hot shower, we are also thinking of putting in a foot tap for our sandy feet if we don't need a full shower. Re: Outdoor shower 14Oct 20, 2011 11:38 am I forgot all about this to change our plans now will cost. BUGGER Will have to see what canbe done later BUGGER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Outdoor shower 16Oct 27, 2011 10:01 am goodyear Thanks everyone for the interest we are well settled into our new home and love our outdoor shower, had plumbing laid as they built and only went for cold and it is great. What did you end up doing in the end with regards to the shower head? Did you get an indoor one or found one specifically for outdoors? Re: Outdoor shower 17May 25, 2012 10:39 pm Just an update, we put in our outdoor shower in December, hot and cold and used an indoor shower head, not sure how it will last but fine so far. Just makes such a difference coming home from the beach and quick shower before going in the house. So glad we did it! Re: Outdoor shower 18Jun 22, 2012 3:31 pm Thats cool Laila,any photo's? Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Thanks for letting us know. The programmer will have a look at this later today. 2 6692 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29621 Natural stone tiles like slate, travertine, and limestone add a timeless, elegant look to… 0 25103 |
