Browse Forums Outdoor Living Re: Pool newbie needs help 2Jan 11, 2010 2:14 pm definatly go salt . maintanance on f/g pool is minimal. check warantee;s on shell & if is is still covered if you diy. speak to recent customers of companies you are thinking going with. what else do you want to know ? what area are you in ? cheers andrew Re: Pool newbie needs help 3Jan 11, 2010 5:02 pm Thanks for the reply...I am in perth south. Looking at 8X4 pool and what about filteration systems n heating options...what the norm and maintenance friendly filter system reqd .lastly wat wld be approx picing for pool this size without the fencing n paving? regards Re: Pool newbie needs help 4Jan 11, 2010 8:39 pm most of the brands of filtration are quiet good waterco, onga, poolrite, hurlcon.dont use chinese unknown brands i use onga because i get good service & back up. they all have base quality up to commercial grade. i use the top end domestic range as the have better flow rate to power consumption ratio & are quieter. filters either cartrige or sand. i prefer cartrige . the use less water & chemicals, take up less space , dont need to be plumbed to waste & cant accidently pump water down the drain when little hands turn a valve.in a dusty enviroment like rural & outback i would allways use a sand filter as fine dust will damage a cartrige prematurly . . cost to supply a pool kit 8 x 4.5is apx $18500 instillation will vary between 6-$11000 depending if your on sand. solar heating will work quiet well in south perth. fitted cost apx $4000 cheers andrew Looking at 8X4 pool and what about filteration systems n heating options...what the norm and maintenance friendly filter system reqd .lastly wat wld be approx picing for pool this size without the fencing n paving? a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8718 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11757 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13662 |
