Browse Forums Outdoor Living 1 Nov 10, 2009 8:05 pm Hi all. I need some advice as to how far my filter should be from the skimmer or to the returns of the pool. Currently its around 25 mtrs away from the skimmer (im on an acre) Were getting some pool reno's done and now is the time to re locate it if need be? Ive been having to literally clean my cartridge filter 3-4 times a week and its driving me insane. Most of the time there is hardly any dirt at all in the cartridge. Reason i have to clean it so much is that the salt cell drops to about half and risks burning the unit out. Im hoping moving it closer would help! Any advice would be muchly appreciated. Thanks! Re: Requiring pool filter advice. 2Nov 10, 2009 8:20 pm For some reason you have this as a new topic multiple times.. pls delete all but one. Built with New Generation (Summit Homes) We own land!... with a slab on it! Plus a shell of a house with stuff inside ! Re: Requiring pool filter advice. 3Nov 10, 2009 9:02 pm Ah crap I was trying to avoid that. ...you are just too quick CL Where you are coming from is where you are going to... Re: Requiring pool filter advice. 5Nov 11, 2009 4:40 pm get the pool reno company to work out the flow rates for distance and land gradient if the pump you have is to spec. then you may have problems other than pump, ie no return valve faulty, air leak etc if pump is under size then spec. it up Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 21525 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12107 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13850 |
