Browse Forums Outdoor Living 1 Aug 20, 2009 2:49 pm Not sure if this is the right spot to post, but I guess its an outdoors type thing. Does anyone have or know of where I might be able to find some plans, or even general dimensions for a kids swing set? I was looking for a fairly simple A-frame type one. An A frame at either end, joined by a beam at the top. Also, is there any rules and regs that need to be adhered to for this sort of thing? Or does it just need to not fall down? Cheers, Pete viewtopic.php?f=38&t=8824 Re: Kids Swing Set - Plans 2Aug 20, 2009 9:22 pm I remember seeing them make one on Better Homes and Gardens not that long ago. Maybe check out the website and see ifthe plans are available. You may also be able to get some from a timber supplier or even Bunnings have free (I think?) plans in their info area. Surely if you GOOGLE it you will find some plans on the net. Good luck. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: Kids Swing Set - Plans 3Aug 21, 2009 11:20 am Not hard, but a little pricey. They used Treated Pine logs in an A Frame format, joined by a coach bolt. Same again on the other side. Concrete them in. Then Another TP log across the top secured by silver strapping (if memory is correct). Drill the holes for the bolts with the eyelets, then add swing and soft ground coverage for those potential accidents. Adrian B I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 10747 Bathroom renovation will likely include a back-to-corner bath and we’re considering a freestanding tap with hand-held shower such as the picture included. My hesitation… 0 22702 After some ideas on making our patio kid friendly . Currently we have exposed aggregate. The patio faces west and is always in sun even though it has a shade directly… 0 1790 |
