Browse Forums Outdoor Living 1 Aug 13, 2009 2:20 pm Hey Guys Long time lurker and now that i've placed a holding deposit on a land, need some help... Building out in Western Sydney on a 600m2 block, however at the back fence there is a "Proposed Easement To Drain Water." Now I discussed it with the agent and how it will effect the future installment of a pool.. they advised that it will not be a problem as the pool pavement can cover this just make sure the pipe is covered by concrete.. Can anyone confirm whether this is indeed true ?? Experiences will be a great help!!.. Thanks guys ~ Land: http://abbotsburymeadow.com.au/Abbotsbury%20Block%20Plans/13479_911_SALES%2036%20(1).pdf All Finally Done March 2012 Re: Drain Water Pipe + Pool 2Aug 13, 2009 4:00 pm You cannot build over an easement without approval from the appropriate authority. I wouldn't see a problem with the pool paving over the easement however. THe one thing I do see a problem with is the pool structure itself in relationship to the pipe. Blog is now up - http://www.jbdave.blogspot.com/ Re: Drain Water Pipe + Pool 3Aug 14, 2009 3:31 pm Thanks JD.. It's certainly going to be tough out back.. Maybe an option would be to have the alfresco overlooking the pool ?!? Hmmm... All Finally Done March 2012 Re: Drain Water Pipe + Pool 4Aug 14, 2009 6:43 pm we had a easement on the property we owned in western sydney, we put a garden shed with pavers across the easement, we were told that they could rip them up and we would need to replace at our own expense if they need to acess it.The people up the road did have pool with pavement over the easement part as you have said but I would check with revlant people in re to this before submitting any plans and as I have always found it best to find out yourself instead of believing another people. finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: Drain Water Pipe + Pool 5Aug 14, 2009 9:35 pm you can build almost anything over an easement (without excavating to a specified depth as directed by local water authority ie: cant build a pool on easement but can concrete over and easement with a pergola) with prior permits and engineering but if they need access they demolish at your expense and you have to pay to re instate. most easement have a standard 2 mtr no build zone, better off long term not building over an easement Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8465 DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5115 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4534 |
