Browse Forums Outdoor Living 1 Aug 11, 2009 10:18 pm Does anyone know where to get supply of PVC material similar to the ones they make blinds out of? We want to use it as water proofing behind a bamboo fence (it will be unseen) so doesn't need to be perfect grade, just cheap and lots of it. Probably 20mx1m wide? Re: PVC material 2Aug 11, 2009 10:20 pm Bunnings Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: PVC material 3Aug 12, 2009 8:22 am Hels Bunnings Surprisingly, no. At least not the 5 or so Bunnings I went to. Re: PVC material 4Aug 12, 2009 1:27 pm Interesting as we bought some off the roll from Bunnings a few years ago, we used it to close in the end of a pergola gable Have a look on eBay as you might be able to pick up some cheap secondhand PVC blinds and then cut them to fit. Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7326 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 852 |
