Browse Forums Outdoor Living 1 Aug 01, 2009 2:21 pm Hi i am laying a new deck in merbu (90x19) and would like to not have any nails or screws showing , has anyone used the invisible side fixings and are they any good ? The deck is going around a new pool and is not covered in , can anyone help? Re: Invisible deck fixing 2Aug 01, 2009 11:51 pm Modwood is available with a secert fixing though with most timber decking you have a visible nail or screw fixing. Most decks are screwed these days as the screw is countersunk whilst a sits proud of the board. Re: Invisible deck fixing 4Aug 02, 2009 6:51 pm A lot of work biscuit joining every board on both sides every 450mm but if you have the time..... Re: Invisible deck fixing 5Aug 05, 2009 4:43 pm We used deck max (http://www.deck-max.com.au/) for our deck - and LOVE the result. Used it for the floor and the raised gardne beds, and the BBQ area and surrounds. Gave it a really clean look. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Invisible deck fixing 6Aug 05, 2009 5:39 pm i too am going the modwood way (i like the milk bottles+wood dust its made from), we like the idea of invisible fixings, however my chippy said we dont have to use the fixing system. he said it was it all comes down to construction (in our case, upside down) 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Invisible deck fixing 7Aug 05, 2009 8:11 pm The secret fixing for Modwood is called 'KlevaKlip' and it is quite exspensive at around $18 per sq metre. The other recommended method is stainless steel screws which are countersunk and sit flush with the boards Re: Invisible deck fixing 8Sep 30, 2009 8:58 pm Here in Perth we use E Plank 86x20 x 3.6 or 4.5m. M&B sales have it. It is actually made from jarrah shorts that are returned to China, dovetailed and glued together after all imperfections have been removed. Absolutely brilliant finish and the special secret fitting is the quickest and neatest we have ever used. Re: Invisible deck fixing 9Feb 22, 2010 7:58 pm you can allways lay pre grooved decking DIY friendly !!! Re: Invisible deck fixing 10Jan 12, 2011 2:29 pm Hey guys - dragging up an old thread here... Looking in this now as we prepare to deck our alfresco and entertaining areas... Has anyone used Klevaklip? http://www.klevaklip.com.au/ We're looking into it and just thought I would seek some feedback on this product or any other "invisible" decking fixing that is available in Melbourne Thanks Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39049 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9570 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 |
