Browse Forums Outdoor Living 1 Mar 02, 2010 9:01 pm hi guys we have a 350mm x 350mm pier in the front of out house 2.6mtrs high we would like to stack stone . just wondering what the easiest way to do it is. alot of the panels are 600mm wide and most corners are too short. is it easy to cut the flat panels for corners? there would be alot of waste. any help would be great. thanks Mark and Alli Re: 350 x 350 stack stone pier 2Mar 03, 2010 9:59 am We have two on our portico. The tiler recommended that we only buy the corners - they are more expensive but there is no need then to mitre the corners on each and every piece. The leftovers (straight pieces) we will use at a later stage for a splashback / feature wall out the backyard. Some things are worth waiting for. Re: 350 x 350 stack stone pier 3Mar 03, 2010 10:25 am We also looked into the stack stone and told corner pieces were the way to go. They can be cut if needed to suite your pier if they are too long. Re: 350 x 350 stack stone pier 5Mar 03, 2010 10:15 pm We got quoted something similar though I have seen stack stone from $60-70sqm. As for quality I couldn't say. Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7465 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 6346 |
