Browse Forums Outdoor Living 1 Jun 30, 2009 4:13 pm Hi I recently got a quote for an 8m long 600mm high retaining wall for the front of my house. I had requested it in timber to keep it as cheap as poss. the quote was over $6500. Does anyone else think this is excessive? Re: retaining wall 2Jul 01, 2009 10:35 am Whilst your quote is excessive; Get it quoted in Masonry. You should find that is more cost efficient at the moment. Labour is more but material is less. "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay Re: retaining wall 3Jul 01, 2009 11:07 am Go with masonry. Others will correct me (hi Davinci) in method and measurements but essentially here is what I would do. To put it into perspective, I bought 400mm x 200mm x 200mm masonry blocks for around $3.60 each i think. 600mm high = three courses of 200mm high blocks. 8 metres = 20 blocks per course so 60 blocks = $216. Get some lengths of Reo and cut them to 1 metre lengths using an angle grinder or bolt cutters. Dig a 450mm wide x 300 deep foundation, line with appropriate reo,the concrete. I would then lay the first cours of blocks in when the concrete is almost dry. Dont forget to use a stringline. I would also hammer in the 1 metre lengths of reo every 4 blocks, so that they stick out 600 from the foundations. Once the first row is dry and solid you can do your next 2 courses. If the wall will be 'load bearing' I wold fill the cores with concrete before moving dirt against the wall. It might take a little while to do it, but it will save you thousands, I kid you not.. Remember you can paint or render the wall once dry. Just a thought Adrian B Re: retaining wall 4Jul 02, 2009 8:02 pm sounds about right adrian (few to many beers when you spelt davini) i would on every second course lay horizontal y123 deform bars this helps to prevent the perp. joints from opening up. also even with out back fill i would core fill due to the lack of vertical strength in besser walls Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16122 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6900 |
