Browse Forums Outdoor Living 1 Jun 02, 2009 7:55 pm Hi, We have recently built a house with Plantation Homes (Henley), and are looking at options for the floor of our Alfresco area. All of the display homes we went through had the Alfresco Area's floor the same height as the internal floor, which made everything flow and really bought the outside in. The majority of these houses had the Alfresco area's tiled. We also would like to do this, however after speaking with a few concretors they refuse to do it as the weep holes are lower than this level, and would therefore cover them up. They advised that this would void any Termimesh warranty we have. My question is, is there anything we can do to have the floor the same height as the internal floor without voiding our Termimesh warranty? Thanks Re: Alfresco Area Floor Height + Termite Barrier 2Jun 05, 2009 1:35 pm The only way would be to use decking or create a sepration between the alfresco floor area and the house floor so you can see the weepholes, an open chanel or something to that effect. Re: Alfresco Area Floor Height + Termite Barrier 3Jun 06, 2009 7:53 pm building with them too and I'm sure most of the display homes I saw at kawana, north lakes and caboolture had decking. That's what I intend to go with leaving 40mm (?) separation between deck and house to allow inspection and to not void the termimesh warranty. ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16395 Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 3801 I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9880 |
