Browse Forums Outdoor Living 1 Apr 23, 2007 6:16 pm we want to make a timber deck and a roof. However it is quite expensive. A 3 x 9 deck with the roof was quoted round $15.000 .
Did someone construct a deck and a patiio on his own? How difficult is this and how much time was needed? and are there some sort of kits at least for the roof and maybe for the underconstruction od the deck? There should be a laundy on hte deck as well (something like a cupboard or anytthig simple) Re: decking + patio DYO 2May 24, 2009 7:19 pm If some one sells you a kit form pergola & timber deck i think you will still need to do a fare bit of cutting and fitting and may be quite difficult if your not a carpenter or in the building game. ***edited by Site Admin*** Re: decking + patio DYO 3May 25, 2009 2:46 pm If you do your research you can do these things yourself, just try to read as much as possible 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: decking + patio DYO 4May 25, 2009 3:23 pm Decks are a fairly easy DIY project though I would not recommend a roof structure if you have no building experience. A lot more can go wrong with a roof such as it being dislodged during heavy winds and killing your neighbour etc. I know that sounds a bit dramatic but it has happened in the past Re: decking + patio DYO 6May 27, 2009 4:47 pm ![]() Decks are a fairly easy DIY project though I would not recommend a roof structure if you have no building experience. A lot more can go wrong with a roof such as it being dislodged during heavy winds and killing your neighbour etc. I know that sounds a bit dramatic but it has happened in the past Hi Luke, can you please let me know what could go wrong? Like not making the structure secure enough etc? We are thinking of building our own pegola with roof later down the track. Thanks Idiots are fun, that's why there is one in every village! - Dr. House - Re: decking + patio DYO 7May 27, 2009 8:19 pm Primarily it needs to be attached to the house properly and any posts anchored into the ground securely. The correct size timber needs to be used for a particular application and it needs to be fastened with the correct fixing. I can help with any design/span needs if you need it Re: decking + patio DYO 8May 27, 2009 10:05 pm ![]() Primarily it needs to be attached to the house properly and any posts anchored into the ground securely. The correct size timber needs to be used for a particular application and it needs to be fastened with the correct fixing. I can help with any design/span needs if you need it aaww thank you very much Luke!!! ![]() ![]() Idiots are fun, that's why there is one in every village! - Dr. House - Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 7683 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 2523 ![]() If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 1911 ![]() |
