Browse Forums Outdoor Living 1 May 16, 2009 8:32 pm Anyone have any phtoos of Merbau timber decking? Would like to have a look at some pics for inspiration etc. Built the Atlantique 37 Mk2 with Carlisle Homes - WE'RE IN!! Building thread: viewtopic.php?f=31&t=14413 ATLANTIQUE 37 MK2 PHOTOS THREAD - updated 22nd August '09 viewtopic.php?f=31&t=22399 Re: Photos of timber decking needed!!! 2May 16, 2009 10:42 pm who was it that did the thread on it? they went right around the house and it looked great. Re: Photos of timber decking needed!!! 3May 17, 2009 11:48 am Check out Adrian's decking here: http://forum.homeone.com.au/viewtopic.php?f=17&t=3229&hilit=deck I know the one Fu means, but can't think whose it was.... Re: Photos of timber decking needed!!! 5May 17, 2009 10:50 pm That is the one Kek. You are a Homeone Encyclopedia. You are the Homeone-a-pedia. Re: Photos of timber decking needed!!! 6May 18, 2009 1:55 pm Here are some pics of our deck - nearly finished. We are just giving the timber time to leach out the oils then we will give it a light sand and an oil. http://i163.photobucket.com/albums/t315/DaisySparkle/deck1.jpg http://i163.photobucket.com/albums/t315/DaisySparkle/deck2.jpg Re: Photos of timber decking needed!!! 7May 18, 2009 5:29 pm Tip: use gal nails, & don't punch them, down so you end up with a 'well' at the head where the water will sit.... Life's too short too drink bad wine Re: Photos of timber decking needed!!! 8May 18, 2009 6:18 pm Hi Hammerhead, DH fixed all the boards using http://www.deck-max.com.au/. It means that there are no screws or nails visible so it looks more streamlined. The dents you see on the seats will be filled with merbu "plugs" and chiselled/sanded to level so hopefully we shouldn't have any water pooling like it is currently after the showers over the weekend. Re: Photos of timber decking needed!!! 10May 18, 2009 9:51 pm Hi, Here is one of our front deck from up top 105713079al1242613248.jpg Here is one from the driveway looking up at the deck with the merbau screen on the front and the board detail under the eaves. 105713079nl1242613248.jpg One looking across the front of the house 105713079ml1242613248.jpg Hope these attacments work OK. Its the first time ive tried. Min Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building at The Ponds Land reg 3/12/09, Land settled 18/12/09 Approved by Design Panel 16/11/09, Submitted to council 24/11/09, Approved by Council 21/1/10 Site Start 21/5/10 http://andyminpondsbuild.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=19800 Re: Photos of timber decking needed!!! 11May 19, 2009 1:38 pm Merbau is a great timber for decking. I recommend the 140mm x 25mm boards. It gives the deck that extra added feel of strength. An oil before and after summer with Intergain Natures Timber Oil will also give your decking that extra life. Good luck Re: Photos of timber decking needed!!! 12May 19, 2009 2:37 pm Hi Clath, Thanks. Yes, we did the wall - wanted to look at something nicer than a grey fence. Cheers. Re: Photos of timber decking needed!!! 13May 19, 2009 11:24 pm DaisySparkle18 Hi Clath, Thanks. Yes, we did the wall - wanted to look at something nicer than a grey fence. Cheers. Sorry should have asked before Their wall tiles i presume? where did you purchase them/ Ive have similar color steppers, dont want to copy you , but think those colors in your wall would match my brick color Re: Photos of timber decking needed!!! 14May 20, 2009 8:18 am They are wall tiles from: Lifestiles 9/ 205 Mornington-Tyabb Rd Mornington VIC 3931 ph: (03) 5973 6913 They were easy to do too! FYI - the wall was made in blueboard, then finished with a render paint. Re: Photos of timber decking needed!!! 15Aug 18, 2009 4:31 pm DaisySparkle18 They are wall tiles from: Lifestiles 9/ 205 Mornington-Tyabb Rd Mornington VIC 3931 ph: (03) 5973 6913 They were easy to do too! FYI - the wall was made in blueboard, then finished with a render paint. Hi daisy, sorry to ressurect such an old thread but I was admiring your pics of the wall and planter boxes. It's just what we are wanting to do at our place. How did you do the planter boxes? That is, did you build them out of timer? If timber did you line them with anything before filling with soil? What about the frame for the wall, anything special for that? Thanks heaps Re: Photos of timber decking needed!!! 16Aug 18, 2009 4:59 pm Damonc - husband built the wall out of blueboard, on a treated pine frame. Built the raised bed/seating out of treated pine sleepers, covered them in merbu, lined the beds with black plastic (put lots of drainage holes in the bottom), filled the very bottom with polystyrene pieces we helped ourselves to from a hopper out the back of a homemaker centre (ahem, gross I know, but made the bed lighter in weight, and cheaper to fill) and then with quality dirt and the top 20cm is the $13 a bag dirt (hence happy plants, well... apart from 1 that is decidedly brownish)... and Bobs our uncle. Actually he's not, his name is Barry. I have lots of step by step photos somewhere that I can post if you like. Start to finish. Here's another pic of it. The kanga paws are just starting their 1st flower. Yeah!!! http://i163.photobucket.com/albums/t315/DaisySparkle/deck-1.jpg Re: Photos of timber decking needed!!! 17Aug 18, 2009 5:56 pm Thanks for the info. That's very helpful. I'd love to see some progress shots of the construction, but only if it's not too much trouble. I think I can see lights in the garden bed, is that correct? Did you run ultra-low voltage for those or is it regular mains power? cheers damon Re: Photos of timber decking needed!!! 18Aug 21, 2009 1:35 pm DaisySparkle18 Damonc - husband built the wall out of blueboard, on a treated pine frame. Built the raised bed/seating out of treated pine sleepers, covered them in merbu, lined the beds with black plastic (put lots of drainage holes in the bottom), filled the very bottom with polystyrene pieces we helped ourselves to from a hopper out the back of a homemaker centre (ahem, gross I know, but made the bed lighter in weight, and cheaper to fill) and then with quality dirt and the top 20cm is the $13 a bag dirt (hence happy plants, well... apart from 1 that is decidedly brownish)... and Bobs our uncle. Actually he's not, his name is Barry. I have lots of step by step photos somewhere that I can post if you like. Start to finish. Here's another pic of it. The kanga paws are just starting their 1st flower. Yeah!!! http://i163.photobucket.com/albums/t315/DaisySparkle/deck-1.jpg WOW DaisySparkle18 your DH did a fantastic job! you must be really pleased with the result I would really love to see the step by step photo's if you wouldn't mind, I would love something like this when we get to it https://forum.homeone.com.au/viewtopic.php?f=31&t=19655 FINALLY slab down 5th SEPT Oct 16 Bricking/ plaster starting Dec 1 Painting started END OF CONTRACT IS UP SOON HURRY UP AND FINISH MY HOME..... countdown to 27th Feb. LATROBE 320 WITH DENNIS FAMILY HOMES Re: Photos of timber decking needed!!! 20Aug 22, 2009 10:55 pm Wow that decking/seat looks great!! I might take that idea up and do something like that along the fence/current deck. Thanks!!! Built the Atlantique 37 Mk2 with Carlisle Homes - WE'RE IN!! Building thread: viewtopic.php?f=31&t=14413 ATLANTIQUE 37 MK2 PHOTOS THREAD - updated 22nd August '09 viewtopic.php?f=31&t=22399 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10971 Building Standards; Getting It Right! Long story short, a toilet room is going to back onto our main bedroom and I want to make it close to soundproof. Im going to build two frames (pretty much a room within a… 0 10213 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15907 |
