Browse Forums Outdoor Living 1 May 15, 2009 4:37 am Ok, it's poll time. I am going to build a house on a 5 acre country block and I want a good size outdoor area for eating and relaxing. My living areas face north and they will open up to the alfresco/verandah area. Would you have an alfresco 8m x 5m (or some other size) or a 4m (or some other size) verandah across the back of the house? The alfresco may look more polished while the verandah may be more in keeping with a country house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alfresco or verandah 3May 15, 2009 6:37 am I agree with verandah reasonings. But both would be lovely, is that out of the question? "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Alfresco or verandah 4May 15, 2009 11:54 am If you want the natural light to get into your house then you need to not have a totally solid roof, so for this reason I am personally building a pergola with a laser light and colorbond roof instead of an 'alfresco' 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Alfresco or verandah 5May 15, 2009 3:12 pm lisanne If you want the natural light to get into your house then you need to not have a totally solid roof, so for this reason I am personally building a pergola with a laser light and colorbond roof instead of an 'alfresco' With a lot of windows on the north side won't light get in with a solid colorbond roof? It wouldn't be direct light of course but there would still be a lot of light I would have thought. I have thought about having a veranda which would be part colourbond and part laserlight so it would let the sun in to heat the house in winter time. However this would mean that in summertime you would not get protection from the heat when sitting underneath the verandah unless you had another sort of cover like shade cloth that you fitted in the different seasons. Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3339 1 2996 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4205 |
