Browse Forums Outdoor Living 1 May 07, 2009 1:58 pm Hi Guy, New to forum but have read posts regularily in the past. My problem is this. Building in Perth with Celebration Homes. Alfresco area has just been completed and on viewing it the roof seems incredibly low. I counted it out and it is at 25c. Is this normal/legal?? it is incredibly low and the supervisor says it is standard and nothing can be done about it. Have other people had similar experiences/problems. I can touch the bloody roof from -1.5c (standing on the sand). It looks cheap and nasty, is there anything I can do?? Matt Re: Alfresco Area Roof Height 2May 08, 2009 12:39 pm DSB Hi Guy, New to forum but have read posts regularily in the past. My problem is this. Building in Perth with Celebration Homes. Alfresco area has just been completed and on viewing it the roof seems incredibly low. I counted it out and it is at 25c. Is this normal/legal?? it is incredibly low and the supervisor says it is standard and nothing can be done about it. Have other people had similar experiences/problems. I can touch the bloody roof from -1.5c (standing on the sand). It looks cheap and nasty, is there anything I can do?? Matt Do you mean 25cm high??? Im a bit confused?? do you have a pic Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Alfresco Area Roof Height 4May 08, 2009 1:31 pm Probably c = course of bricks, making 25c about 2750 mm? mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Alfresco Area Roof Height 5May 08, 2009 1:40 pm to_do_list Probably c = course of bricks, making 25c about 2750 mm? 2750 is a over 9ft. thats a high ceiling, not low! or is it 2750 to top of roof. ahhhhh DSB help us out, what ya talkin bout?? Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Alfresco Area Roof Height 7May 08, 2009 2:09 pm borg 25 coarses of brick is 2150mm yeah that would be low. Yep you're right...I've been laying them as pavers and edging and I've got 110 mm stuck in my head...which is the depth not height ... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Alfresco Area Roof Height 8May 08, 2009 5:01 pm Yeah confusing huh? 25c?? Have since worked out that it means 25 coarses of bricks, and also worked out that 25 coarses of brick is not very high. (25 bricks high from the slab and then the ceiling. sorry for the confusion haha 25cms) Maybe if they had bothered to label it somthing that a regular person would understand I wouldnt be in this problem. It is very low. Any suggestions? Builders said ceiling cant be made higher (Too late, timbers done etc....) Has anyone else built with Celebration Homes and gone for the alfresco option? Did you have the ceiling raised, did you manage to make it look ok? Edited for clarity Re: Alfresco Area Roof Height 9May 09, 2009 11:14 am check your build plan, if it is that height on plan then nothing the builder will fix, if it is lower than on plan then the builder should rectify Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16691 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7792 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4235 |
