Browse Forums Outdoor Living Re: Concrete Veranda 2May 11, 2009 10:58 am Yes you can, you would first install battens that would sit 20mm below your finished fllor height, (internal) so as when the decking boards where installed you have a smooth transition from inside to out, with minimal to no tripping hazard. In summary: Very easy to do. Ben LEADING THE WAY IN BUILDING AND CONSTRUCTION BUILDERSEDGE PTY LTD i think option 2 is much better with easy access to the garden without having to walk through the new sunroom which makes it a better room for guests and TV .a simple… 2 8215 There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2969 |
