Browse Forums Outdoor Living 1 Mar 26, 2009 3:04 pm Hello guys....the ceiling above the outdoor entry looks horrible. i was thinking of doing 2 options. 1. buying some pine wood, cutting it, painting it and putting it in strips accross from left to right. leaving gaps every 5 cm or so. 2. buying some decking timeber, and just putting it up there same method. (3.) installing 3x lights instead of that ugly single exposed fixture. Can anybody suggest: 1. the most suitable timber/material to place up there 2. any hints for lighting to be used? much appreciated papermate. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help ideas to renovate outside ceiling? PICS included 3Mar 26, 2009 7:25 pm Cheapest way would be to line it with fibro and paint it. Other than that you could use cedar lining boards or alike. I think gaps would look funny Re: Help ideas to renovate outside ceiling? PICS included 4Mar 27, 2009 3:57 pm Mr Smith hi i personally would put timber floor decking in, looks nice, and then get a few downlights put in. make it look heaps better timber decking would be best. but the area is 6m long x 2.15m wide and requires approx 20 x boards (using 2cm gaps). at $4.95 a metere that works out to be around $651.00. At first i thought this was way too much, but does anyone think this is out of the ordinary? total area is approx 13m2 Dukekamaya I think gaps would look funny without 2 - 3 cm gaps the cost becomes painful. above calculating is 68mm wide boards with 20mm gap. without gaps, that would total $939.00 i think without decking timber, any other material would look cheap. pine looks cactus, only seen merabu decking material.....advice?? Re: Help ideas to renovate outside ceiling? PICS included 6Mar 27, 2009 7:37 pm if you really want the wood look, why not just sand back and restain what is there? "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Help ideas to renovate outside ceiling? PICS included 8Jun 11, 2009 4:47 pm ok. i finished, some weeks ago, but didnt post pics. end result. used merbau $4.95 a metere, about 109 lineal meters. whole job cost me about $600 including Oil Stain Paint, screws and materials. *EDIT* it wont let me upload the finished picture.... Re: Help ideas to renovate outside ceiling? PICS included 9Jun 11, 2009 9:27 pm Depends whether you want to make a feature of it or not. FC sheeting would be the most cost effective, allowing you to spend $$$ elsewhere where you aren't bending you neck to 90 degrees to appreciate it! Life's too short too drink bad wine Re: Help ideas to renovate outside ceiling? PICS included 10Jun 11, 2009 11:02 pm donuts if you really want the wood look, why not just sand back and restain what is there? I'm hearin' ya on that. Re: Help ideas to renovate outside ceiling? PICS included 11Jun 12, 2009 12:14 am donuts if you really want the wood look, why not just sand back and restain what is there? @Donuts Good idea! as to lighting, you preferred flourescent or just simply a small bulb? Google search for green friendly bulb. Re: Help ideas to renovate outside ceiling? PICS included 12Jun 12, 2009 12:23 am donuts if you really want the wood look, why not just sand back and restain what is there? I'm hearin' ya on that. too much work, too fiddly to get in there. want to enclose it, think it will work better. i wish i could post the finished product. ill try again..... just tried. i have an error. : Sorry, the board attachment quota has been reached. Re: Help ideas to renovate outside ceiling? PICS included 13Jun 27, 2009 9:03 pm papermate, try http://www.photobucket or http://imageshack.us/ to host your pictures the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11800 if the original house is in good condition most of what you listed could be added in stages without the need for KDR and costs and disruption of having to live elsewhere… 1 13633 hey there! 😊 so, it’s kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20857 |
