Browse Forums Outdoor Living 1 Feb 26, 2009 11:44 am We are getting a gas point put in our alfresco area, however it never occurred to me whether or not natural gas will be cheaper to run our bbq on or the lpg we currently use. Does anyone know?
Thanks! Re: Cheaper - Natural Gas or LPG? 2Feb 26, 2009 12:24 pm Natural gas will be cheaper per mega joule however the additional cost with the installation of a point and the cost to upgrade the jets on the BBQ will be a bit.
Bascially you get it not because you save money - you get it for the convienience of always having gas and not running out. Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6862 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20351 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3762 |
