Browse Forums Outdoor Living 1 Jan 19, 2009 9:41 am Hi
any suggestions for outdoor built in bbq adjacent benchtop . It will get rain and sun. Told granite and stainless steel are the main options but are there anyother better options . I dont like stainless steel as it will be glary in the sun I think. thanks Mike 2/3 of the way thru the build Re: outdoor bbq benchtop. 2Jan 19, 2009 10:10 am Friends of ours used some left over slate flooring. You've have to seal it though. I've also seen floor tiles used for the BBQ bench tops. Re: outdoor bbq benchtop. 3Jan 19, 2009 10:39 am We're going to build one and at this stage we plan to use some leftover floor tiles - they can be sealed if need be, but should stand up to the weather OK. I also have some leftover pebble feature strips, which I'll probably use too - those definitely have to be sealed.
We haven't finalsied the exact design but it'll be rendered Hebel and we'll most likely edge the benchtop in decking timber to give a neat finish. Re: outdoor bbq benchtop. 4Jan 19, 2009 10:56 am We used floor tiles on the top of ours. It has been out in the elements for 4 years and has not deteriorated. Re: outdoor bbq benchtop. 5Jan 19, 2009 10:58 am Should have said we didn't seal it either but would probably prolong the life of the tiles. Re: outdoor bbq benchtop. 7Jan 20, 2009 9:09 pm This one from an older thread looks like tiles (Paula?) It looks excellent
https://forum.homeone.com.au/viewtopic.php?t=6241 I'll also be installing one in our alfresco (just doing the design now) and was thinking of rendered Hebel blocks too. Good luck and post pics/design if you can. Building the Caprice33 by Provincial Homes. Now it's time for the landscaping http://jacksonsbuild.blogspot.com Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12921 Thanks for letting us know. The programmer will have a look at this later today. 2 6681 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29607 |
