Browse Forums Outdoor Living 1 Jan 08, 2009 10:03 pm actually its more of a bali hut but without the thatch
I got quoted 5k so I decided to build it myself in treated pine with a colourbond roof...I know, not as nice as thatch but heaps cheaper essentially it will be 4 post, 1 in each corner, 6m X 4m what i need to know is what size timber to use on the roof it will be flat and supporting colourbond what size do i need for the 6 metre span from post to post? any and all advice would be appreciated thanks guys!! Re: Gazebo tips anyone? 2Mar 11, 2009 11:58 am Been looking at gazebos and found a great source for ideas has been local council structures; they are generally built sturdy and have been built round the place right up to big sizes for functions and cermonies. Can be a good reference for design and materials. Can't help with your maths though mate, good luck. .. Re: Gazebo tips anyone? 3Mar 11, 2009 6:07 pm Use 290x45 pine for the beam if spanning the 6 metre or 190x45 if using a post in the middle.
140x45 for the rafters ( 140x45 will just span the 4 metre with colorbond roof - if you go longer you will need 190x45) If the rafters are spaced at 1 metre use 70x45 for the battens. Re: Gazebo tips anyone? 4Mar 21, 2011 1:27 pm Building a gazebo requires four basic steps. The first step is to build the frame for the deck floors, the second is to assemble the walls, the third is to add the roof, and the last is to make the finishing touches. You can find lots of information and some guides online that can help you build an awesome Gazebo. Please some photos here when it's done. Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7215 Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14242 Wish you all the best. Once you signed the contract, they will find millions excuses to charge you. And have seen their sites unfinished for a long time. 4 24807 |
