Browse Forums Outdoor Living 1 Dec 08, 2008 8:44 pm Hi,
Has anyone had experience with Decking around a pool? My main queries are how close to the concrete shell can I dig the post holes? For example down one side of the pool we will have 1m wide decking. Assuming I will need a post at the exterior edge, how close can I get to the concrete shell - I cant fix a ledger to the shell obviously. Along an 8 meter length that is a lot of post holes for 8m sq deck! Also is there a secret for getting the deck surface flush with the coping edge of the pool? Thanks! JC Re: Decking around an in-ground Pool 2Dec 09, 2008 7:07 pm I'd be using a composite decking board. Timber decks around pools get the worst of the elements and generally look terrible after a while. The maintanance needed to keep it looking good would keep you out of the pool and working around it instead Re: Decking around an in-ground Pool 3Dec 09, 2008 8:01 pm Thanks for the advice.
How do they compare in looks, I haven't seen any close up? Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12052 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13818 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 13046 |
