Browse Forums Outdoor Living 1 Feb 05, 2024 4:09 pm Hi, Really struggling to find some consistency amongst Span Tables, can anyone help @StructuralBIMGuy? I'm building a low deck that is 10.5x7m using Single Span Joists 140/45 @ 450 and Continues Bearers 2x140/45 I'm getting mixed feedback RE: Span Tables Using the below I concluded to Bearer Spacing @ 2700 and Joist @ 2100 https://wilsontimbers.com/features/seas ... pan-tables However, because of the following tables I'm unsure https://carrollswholesale.com.au/magna- ... k-bearers/ http://www.5startimbers.com.au/download ... Design.pdf https://www.davidstimber.com.au/resourc ... an-tables/ Any guidance? or some direction which table to stick with. Thank you, In general, a member continuous span means it’s continuous (one whole piece of timber/steel or any material) over at least three supports (two spans). Single span means… 1 7108 So, how is the comparison between the two ( Alpha and Hebel ). Do you still put the yellow/red tounge over the alpha also or it's not required and their noise reduction… 16 7877 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 23033 |
